Applying a Sort Order to a Table
When you apply a sort order to a table, Monarch Classic re-displays the table in the order specified by the sort order definition.
Select an active sort from the Active Sort drop-down on the Table View ribbon:
Note: To turn off sorting, select No Sort from the drop-down list.
