Saving Calculated Fields
You may create as many calculated fields as you like with the following restrictions:
  • The maximum number of fields allowed in a Monarch Classic table is 512, including natural fields (i.e., fields extracted from your reports) and calculated fields.
  • The maximum data length of all table fields is 4000 characters.
Calculated fields are saved along with natural fields in your Monarch Classic model files. When you use a model file with a new instance of a periodic report, the fields are recalculated to yield up-to-date information. To learn more about model files, see, Working with Model files.
