Closing a Report
When you close a report, Monarch Classic removes the report from the Report window. Any data extracted from the report is deleted from the Table and Summary windows. When the focus is next given to either the Table or Summary window, the data set is recalculated to reflect the deleted data.
If only a single report is open, Monarch Classic closes the Report window, as well as the Table and Summary windows (if either is open).
Closing a report
Do one of the following to close a report:
  • Right-click on the report on the Report Files selector, then select Close File on the context menu.
  • Select the File tab, then Close, then Report.
Closing a report (and all other files)
To close all open files, select the File tab, and then Close All.
© 2025 Altair Engineering Inc. All Rights Reserved.
