Overview: Settings
Monarch Classic maintains a host of settings that you can use to establish default input and export folders, report translation options, and display options, among others.
Defaults are saved in the HKEY_CURRENT_USER section of the Windows Registry.
Several settings are also saved in your model files. These settings can be tailored for different reports. Settings saved in a model file take precedence over settings saved in the Registry. The following table indicates where each setting is saved.
Setting |
Project File |
Model File |
Registry |
Data extraction templates |
No |
Yes |
No |
Field characteristics (including name, type, data length, decimals, column width, display order, and the repeat field values setting) |
No |
Yes |
No |
Calculated field definitions |
No |
Yes |
No |
External Lookup parameters |
No |
Yes |
No |
Filter definitions (including the active filter setting) |
No |
Yes |
No |
Sort order definitions (including the active sort order setting) |
No |
Yes |
No |
Summary definitions (including chart definitions and active summary setting) |
No |
Yes |
No |
Report, Table, and Summary print settings |
No |
Yes |
No |
Report, model, import/join, portable report/project, and export folders |
No |
No |
Yes |
Input, import/join, and export file extensions |
No |
No |
Yes |
Input file(s) |
Yes |
No |
No |
Import database reference |
Yes |
No |
No |
Import database password |
Yes |
No |
No |
PDF password |
Yes |
No |
No |
Import/join, and Export file types |
No |
No |
Yes |
Date format (interpretation of report dates) |
No |
Yes |
Yes |
Date range for YY (interpretation of 2 digit years) |
No |
Yes |
Yes |
Date/Time Extraction Patterns |
No |
Yes |
Yes |
Trap Case Sensitivity |
No |
Yes |
Yes |
Decimal character (interpretation of report numbers) |
No |
Yes |
Yes |
Ignore form feed characters |
No |
Yes |
Yes |
Ignore unused print control characters |
No |
Yes |
Yes |
Ignore Leading control characters |
No |
Yes |
Yes |
Force Page Break After __ Lines |
No |
Yes |
Yes |
Include field names as first row of output |
No |
Yes |
Yes |
Enforce DBF field naming rules |
No |
Yes |
Yes |
Pad fields with one space |
No |
Yes |
Yes |
Map Characters Above 127 To ASCII/ANSI |
No |
Yes |
Yes |
Pad numeric fields with zeros, suppress decimal point, use trailing negation. |
No |
Yes |
Yes |
Use "quoted" character fields in delimited text files |
No |
Yes |
Yes |
Delimiter character for delimited text files |
No |
Yes |
Yes |
Suppress zero values |
No |
Yes |
Yes |
Null value display string |
No |
Yes |
Yes |
Default row height for column titles and data rows |
No |
Yes |
Yes |
User-edited field values |
Yes |
No |
No |
Auto-update and hidden settings |
No |
No |
Yes |
The Options Window
The Options Window allows you to tailor your Monarch Classic settings. This window can be accessed by clicking Options from the Home ribbon.
