Export Ribbon Quick Reference
The Export View ribbon displays when Export is selected from the Home ribbon or Monarch Classic's window tabs.
This ribbon will help you define, modify, and run exports.
Button
Launches the Export Design window, which you can use to define the properties of your export.
Adds all defined exports to the Export Job list.
Clears selected exports from the Export Job list.
Clears all exports in the Export Job list.
Creates a new export and adds it to the Export selector.
Runs all exports in the Export Job list.
