Export Properties: IBM Cognos Analytics
The table below describes the properties that can be specified for exports to IBM Cognos Analytics.
Properties
Table The name of the selected table to be exported.
Export Type The file type to which your export will be saved.
Table Name
This setting specifies the table name data will be exported to. Enter the name of the table to which data will be exported. You can embed macros (of the form &[macro]) in the table name.
In creating a table name, the following rules apply:
  • Table names must be between 1 and 255 characters.
  • They must not start or end with whitespace characters.
  • They must not contain any of the following: \ "
Note that issues in compliance with these rules will prevent you from performing the export. Hover your mouse over the Table Name field to display the rules to consider in creating your table name.
Filter
This setting specifies which filter, if any exist, to apply to the table when it is exported.
When All Filters is selected as a filter option, exports will automatically be named according to the file name.
Sort
This setting specifies what sort to apply to the table when it is exported.
When Table Exists
This setting specifies what Data Prep Studio should do if a table or sheet with the same name you specified already exists. The options are as follows
  • Overwrite
  • Skip
IBM Cognos Analytics Url This field displays the IBM Cognos Analytics URL specified in the server settings.
Export All Rows/Limited Rows For tables with defined row limits, this setting specifies whether the defined row limits should be respected during export. Select the appropriate checkbox to instruct Data Prep Studio to export all rows or only those rows that fall within the limit you have set.
© 2025 Altair Engineering Inc. All Rights Reserved.
