Export Properties: CSV
The table below describes the properties that can be specified for exports to CSV.
Property |
Description |
GENERAL PROPERTIES |
| Table | The name of the selected table to be exported. |
| Export Type | The file type to which your export will be saved. |
Export File System |
This field describes the file system to which your table will be exported.
Note: Credentials for cloud-based storage systems can be specified in the Server section of The Application Default Settings. |
Export Location |
This setting describes where the export file will be saved and what its name will be. Enter the path and name of the export file. You can embed macros (of the form &[macro]) in the file name. |
File Extension |
This setting specifies the extension to use for the export file. It is enabled only when the Filter setting is set to "All Filters." |
Filter |
This setting specifies what filter to apply to the table when it is exported. When All Filters is selected as a filter option, exports will automatically be named according to the file name. |
Sort |
This setting specifies what sort to apply to the table when it is exported. |
Include Column Headers |
Selecting this setting instructs Data Prep Studio to include the column header in the export file. This header will become the first line in the export file. |
Delimiter |
This setting specifies data delimiter for CSV files. Select a delimiter from the drop-down. The delimiter will be used to separate column values. |
Text Qualifier |
This setting specifies a text qualifier for CSV files. Select a text qualifier from the drop-down. The text qualifier tells you where text values begin and end. This is useful when you have text values that may contain the delimiter character you selected above. |
Quote column names |
When selected, this setting instructs the application to enclose column names in quotes. |
When File Exists |
This setting specifies what Data Prep Studio should do if a file with the same name exists in the folder you specified in the Export Location field. Select an action if the export file already exists:
Encoding Type |
This setting specifies which encoding type to apply to the export file. At present, the encoding types Code Page, UTF-8, UTF-16LE, and UTF-16BE are accepted. |
Code Page |
When the encoding type selected is Code Page, this setting specifies which code page to apply to the export file. |
Append DOS end-of-life character (x1A) |
This option determines whether or not a DOS end-of-file character (x1A) is appended to the end of the file. This option is provided to enable compatibility with systems that expect the data in this format. This end-of-file character is often known as Control-z. |
Legacy compatibility mode - Ignore format customizations during export |
Enabling this option will cause column format customizations to be ignored during the export of numeric and date columns. Using Monarch Classic formatting, numeric values are exported using the localized decimal separator of the current system. Meanwhile, date values are exported based on the Date Format setting. |
Date Format |
When legacy compatibility mode is selected, this setting allows you to specify the date format to apply to date fields in the exported file. |
| Export All Rows/Limited Rows | For tables with defined row limits, this setting specifies whether the defined row limits should be respected during export. Select the appropriate checkbox to instruct Data Prep Studio to export all rows or only those rows that fall within the limit you have set. |
Summary |
If the table to be exported is a summary, this setting specifies which summary to include in the export. When All Filters is selected as a Filter option, you will be unable to select All Summaries as a Summary option. You can select All Summaries as a Summary option by deselecting All Filters as a Filter option and selecting No Filter instead. |
Measure |
This setting specifies which measure should be applied to the exported summary. It is enabled when only a column key is defined in the summary. |
Split |
This setting instructs the application to create a separate file or table when a distinct value of the first key is encountered in a summary. |
Drill Level |
Specifies the drill level to apply to the exported summary. A higher drill level indicates more columns displayed in the output table. |
