Editing Appends
Once defined, you can still edit an append definition from the Prepare Window. You can, for example, change the columns to display in the appended table or choose a different matching type.
  1. Do one of the following:
    • Right-click on the appended table and select Edit Append.
    • Click on the Edit Append icon on the Append dialog.
  1. Modify the append according to the guidelines provided in Appending Tables Using the Append Dialog
  1. Click OK on the Append Helper to complete the edit append operation.
Related Links
