Editing a Template
You can edit a template to change its name, trap, or column definitions.
Select the template you wish to edit from the Templates list.
The Traps and Columns associated with the template are displayed on the Traps and Column List:
Do one of the following:
Click on the edit icon
if you want to change the template name.
Select the delete icon
to delete the template.
Edit the traps and columns associated with the template. Refer to Refining Traps for details
