Add External Model Dialog
Use this dialog to add an external model to the list displayed on the External Functions Library dialog.
Select Functions from the Table Design ribbon.
Select Manage External Functions to display the External Functions Library dialog.
Click Add External Model.
Provide the necessary details using the table below as a guide.
Click the OK button to save the settings and close the dialog. The External Functions dialog now lists the model and its functions.
Click OK to save the settings and close the dialog.
The following table describes the options for this dialog.
Field |
Description |
Name |
Specifies the name of the external model. |
Model |
Displays the path to the external model. Select the model by clicking the adjacent folder icon. |
Folder Icon |
Selects the desired model via the Open File dialog. |
Type of Link |
Selects the type of link to use:
OK |
Saves the new external model(s) settings and closes the dialog. |
Cancel |
Cancels the addition of a new external model and closes the dialog. |
Help |
Displays this help topic. |
