The stability conditions of explicit scheme in SPH formulation can be written over cells
or on nodes.
Cell Time Step
In case of cell stability computation (when no nodal time step is used), the stable time step is
computed as:
is the user-defined coefficient (Radioss option /DT or /DT/SPHCEL). The value of
=0.3 is recommended. 1
Nodal
Time Step
In case of nodal time step, stability time step is computed in a more robust
way:
at particle
Use the following notations, if kernel
correction:
Or, if no kernel correction:
Recalling that apart from the artificial viscosity terms:
write
Where,
is the relative displacement of particles
and
. Keeping the only first order terms leads to:
Where,
that is
Same reasoning leads to:
So that
Stiffness around node
is then estimated as:
