Features
Finite Element Analysis using Radioss
- Solutions
- Nonlinear explicit structures
- Nonlinear implicit structures
- Explicit transient CFD
- Arbitrary Lagrangian Eulerian (ALE)
- Smooth Particle Hydrodynamics (SPH)
- Elements
- Beams and Trusses
- Springs and Multi-strand element
- Isotropic, Orthotropic and Composite Shells (4-nodes and 3-nodes)
- Isotropic, Orthotropic and Composite Thickshells (Hexahedron, Pentahedron)
- Isotropic and Orthotropic Solids (Hexahedron, Pentahedron, Tetrahedral)
- Axisymmetrical and plane strain solid (Quad, Tria)
- Materials
- Elasto-plastic materials
- Hyper and Visco-elastic materials
- Composite and Fabric materials
- Multiscale materials
- Concrete and Rock materials
- Honeycomb materials
- Connection materials
- Other materials (Void, Elastic material, Spring material, etc.)
- Multi-material, Fluid and Explosive materials
- ALE and CFD options
- Viscosity options
- Leakage options
- Thermal options
- Equation of State
- Failure models
- Constraints
- Rigid Bodies
- Boundary Conditions and Constraints
- Rigid Link
- Rigid Walls
- Joints
- Tied Contact
- Flexible Body
- ALE and CFD Constraints
- SPH Constraints
- General Tools
- Sensors
- Fixed or Moving Skew or Frames
- Multi-Domain technique
- Unit System
- Damping options
- Dynamic relaxation
- Load Cases
- Concentrated Loads
- Pressure Loads
- Initial Conditions
- Initial and Reference State
- Thermal Load
- Contact Interfaces
- Kinematic Constraint
- Penalty Method
- Lagrange Multiplier Method
- Automatic Penalty Lagrange
- Hertz Formulation
- ALE Interfaces
- Monitored Volumes (Airbags)
- Uniform Pressure Method
- Finite Volume Method
- Output Database
- Time History (Element, Contact, Node, Monitored Volumes, etc.)
- Section Forces
- Accelerometers
- Animation Output
- Multiple Engine Files
- Restarts
- Load Case modifications
- Time Step controls
