SPL
I/O Options and Subcase Information Entry The SPL command can be used in the I/O Options or Subcase Information sections to request Sound Pressure output for all subcases or individual subcases, respectively. SPL can only be requested for frequency response subcases.
SPL = option
| Argument | Options | Description |
| format | <H3D, PUNCH, blank> | |
| option | <ALL> Default = ALL  |
- When the SPL command is present, Sound Pressure is output for all microphone grids for all frequency response subcases.
 - The Punch file format for
                        SPL results is:
Format GID G Real/Mag Sound Pressure Imag/Phase Sound Pressure Sound Pressure Level Example 9252 G 1.943054E+06 3.226665E+02 1.257697E+02  - Acoustic pressure (SPL) output from radiated sound analysis (via the RADSND card) can be defined as a response (via DRESP1 and RTYPE = FRPRES) in topography, topology, and free shape optimization.
