RADSND
Bulk Data Entry Defines a set of grid points where the sound will be calculated as well as the panels that are generating the sound.
| RADSND | RSID | MSET | |||||||
| "PANEL" | PID | PID | PID | etc. |
| RADSND | 10 | 100 | |||||||
| PANEL | 101 | 103 |
| RSID | Radiated sound set
                                identification number. No default (Integer > 0)  |
| MSET | ID of a
                                    SET of field grids (microphone locations) at
                                which sound levels will be calculated. The sound levels output at
                                these grid points are due to panel vibrations (specified separately
                                in the PANEL and PIDi fields.
                                    4 No default (Integer > 0)  |
| PANEL | Flag indicating that the
                                following panel ID's will contribute to the sound at the
                                    MSET grids. 4 No default (Character)  |
| PIDi | Panel identification
                                number of the PANELG Data
                                Entry of type "SOUND" data. No default (Integer > 0)  |
- At least the first panel ID is required.
 - Multiple continuations or multiple RADSND with the same SID are allowed if more than 7 SOUND panels need to be defined.
 - The RADSND Bulk Data Entry is referenced by the RADSND command in the Subcase Information section of the input data.
 - The MSET and
                    PIDi fields are used to specify the microphone locations
                (receiving grids) and the vibrating panels (source grids), respectively.
- RADSND Data Entry Field
 - Description
 - MSET
 - References microphone grid sets (receiving grids)
 - PANEL, PIDi
 - Reference vibrating panel ID's (source grids)
 - Acoustic pressure (SPL) output from radiated sound analysis (via the RADSND card) can be defined as a response (via RTYPE = FRPRES) in topography, topology, and free shape optimization.
