SINTENS
I/O Options and Subcase Information Entry Used to request Sound Intensity output for all frequency response subcases. The SINTENS command can be used in the I/O Options or Subcase Information sections to request Sound Intensity output for all subcases or individual subcases, respectively.
SINTENS(type) = option
| Argument | Options | Description |
| type | <PANEL, NOPANEL> Default = PANEL  |
| option | <ALL> Default = ALL  |
- When the SINTENS command is present, Sound Intensity is output for all RADSND panel grids and all microphone grids for all frequency response subcases.
 - Sound Intensity results (via SINTENS) are output to the .h3d file.
 - SINTENS can only be requested for frequency response subcases.
 - Sound intensity is always output for microphone locations regardless of the specified type (PANEL/NOPANEL).
