Bulk Data Entry 1D rotor definition. Specifies grids that determine
        the Rotor Line model.
                            | (1) |
                            (2) |
                            (3) |
                            (4) |
                            (5) |
                            (6) |
                            (7) |
                            (8) |
                            (9) |
                            (10) |
                            | ROTORG |
                            ROTORID |
                            GRID1 |
                            GRID2 |
                            etc. |
                            GRIDn |
        Alternate Format
                            | (1) |
                            (2) |
                            (3) |
                            (4) |
                            (5) |
                            (6) |
                            (7) |
                            (8) |
                            (9) |
                            (10) |
                            | ROTORG |
                            ROTORID |
                            GRID1 |
                            THRU |
                            GRID2 |
                            | (1) |
                            (2) |
                            (3) |
                            (4) |
                            (5) |
                            (6) |
                            (7) |
                            (8) |
                            (9) |
                            (10) |
                            | ROTORG |
                            25 |
                            2345 |
                            2356 |
                            2400 |
                            2450 |
Example (Alternate Format)
                            | (1) |
                            (2) |
                            (3) |
                            (4) |
                            (5) |
                            (6) |
                            (7) |
                            (8) |
                            (9) |
                            (10) |
                            | ROTORG |
                            30 |
                            2300 |
                            THRU |
                            2400 |
                            | Field |
                            Contents |
                            SI Unit Example |
                            | ROTORID |
                                        - setid
                                        - The identification number of a rotor.
                                <INTEGER > 0>
                            | GRIDi |
                            List of grids that define
                                the rotor line model. No default <INTEGER > 0>  |
                            | THRU
                                (optional) |
                            Flag indicating that a
                                range of grid identification numbers is defined. The initial and
                                final grids are specified on the fields either side of the field
                                containing the THRU flag. |
            - All grid point entries specified on the
                    ROTORG entry must be unique. The program will run into an
                error, if duplicate grid entries are specified.
            - Multiple ROTORG entries
                can be defined with the same ROTORID.
            - This ROTORG entry is
                    used to define a 1D rotor; therefore, for a specific ROTORID,
                    all grids specified on the ROTORG entry must be collinear.
                        OptiStruct automatically checks if the grids are
                    collinear during a run.
            - Rotors in frequency response and complex
                eigenvalue solutions can be replaced using superelements. Superelements can be
                attached to the grids that define the rotor in the ROTORG Bulk
                Data Entry. Craig-Bampton Nodal Formulation (CBN) or Guyan Reduction (GUYAN) can be
                specified on the METHOD field in the CMSMETH Bulk Data Entry to generate the
                superelements. The superelement replaces the beam elements used to model the rotor.
                The ASET grid points should correspond to the
                    GRIDi points specified on the ROTORG Bulk
                Data Entry. The interface grid points of the superelement used to model the rotor
                should be exactly the same grid points defined on the ROTORG
                entry. The General Modal Formulation (GM method) cannot be used to generate
                superelements for Rotor dynamics.
            - If superelements are not used, connections
                between grids in the Rotor Line model and those not listed on the
                    ROTORG entry must be defined using MPC's
                or rigid elements.
            - If superelements are used, connections
                between grids in the Rotor Line model and those in the residual structure must be
                defined using MPC's or rigid elements.
            - The mass of the Rotor Line model should be
                defined on the grids defined on the grids specified by the ROTORG
                Bulk Data Entry.
                - The ROTOR Bulk Data Entry can be used to
                    define 3D rotor models.
                - For more information, refer to Rotor Dynamics in
                    the User Guide.
