ROTOR
Bulk Data Entry 3D Rotor Definition. Specifies list of sets, elements or properties that comprise the rotor 3D model.
| ROTOR | ROTORID | ||||||||
| LTYPE | ID1 | ID2 | ID3 | etc. | |||||
| AXIS | GID1 | GID2 |
| ROTOR | 10 | ||||||||
| SET | 1 | THRU | 3 | ||||||
| AXIS | 101 | 102 |
Definition
| ROTORID | Identification number
                                    of a rotor. No default (Integer > 0)  |
| LTYPE | Indicates the item
                                    type in the list references elemental set IDs, element IDs or
                                    property IDs.
 No default (Character)  |
| IDi | IDs of sets, elements
                                    or properties comprising the rotor. No default (Integer > 0)  |
| AXIS | Defines grid points which define the axis of rotation. | |
| GID1, GID2 | IDs of grids
                                    comprising the axis of the rotor. No default (Integer > 0)  |
- Fixed reference frame method is adopted for 3D rotor dynamic analysis via the ROTOR Bulk Data Entry.
 - Supported element types:
- 0D elements : CONM1, CONM2
 - 1D elements : CBEAM, CBAR
 - 3D elements : CHEXA, CPENTA, CTETRA, CPYRA
 - The THRU option is supported in lists of elemental set IDs, element IDs and property IDs. Different LTYPE lists can be used together.
 - 1D rotors can be defined via the ROTORG Bulk Data Entry.
 - For more information, refer to Rotor Dynamics in the User Guide.
