REQUEST
I/O Options and Subcase Information Entry The REQUEST command can be used in the I/O Options or Subcase Information sections to select a multibody request definition to be used in a multibody problem.
REQUEST = option
- Only one REQUEST entry can be present for each subcase.
 - This Subcase Information Entry is only valid when it appears in a multibody subcase.
 - If the SID referenced by the REQUEST Subcase Information Entry matches with the SID defined for an MBREQ Bulk Data Entry, the information on this entry alone is selected. However, if a MBREQ Bulk Data Entry does not have the referenced SID defined, any of the multibody motion entries: MBREQE or MBREQM which have this SID will be selected.
 - If present above the first subcase, it is applied to each multibody dynamics subcase without a REQUEST entry.
