MBREQM
Bulk Data Entry Defines a multibody solver output request to output displacement, velocity, acceleration, or force with respect to markers.
| MBREQM | RSID | RID | TYPE | IMARK | JMARK | RMARK |
| MBREQM | 20 | 234 | DISP | 20 | 30 | 10 |
| RSID | Request set
                                    identification number. (Integer > 0)  |
| RID | Request identification
| TYPE | Output type:
 No default  |
| IMARK | Marker ID. The output
                                    request is usually of IMARK with respect to
                                        JMARK resolved in
                                        RMARK. (Integer > 0)  |
| JMARK | Marker ID. If not specified, the results are with respect to global frame. Default = blank; (blank or Integer ≥ 0)  |
| RMARK | Reference marker ID.
                                    Request ID must be unique with respect to all other MBREQM and MBREQE cards. If not specified, the results are resolved in the global frame. Default = blank; (blank or Integer ≥ 0)  |
- Request set will be specified in the subcase definition.
