RANDT1
Bulk Data Entry Defines time lag constants for use in random analysis autocorrelation function computation.
| RANDT1 | SID | N | T0 | TMAX |
| RANDT1 | 5 | 10 | 3.2 | 9.6 |
| SID | Random analysis set
                                identification number. (Integer > 0)  |
| N | Number of time lag
                                    intervals. (Integer > 0)  |
| TO | Starting time lag. (Real ≥ 0.0)  |
| TMAX | Maximum time lag. (Real > TO)  |
- At least one RANDPS entry must be present with the same set identification number.
 - The time lags defined on this entry are
                given by:
 - Similar to RANDPS Bulk Data Entries, the RANDT1 Bulk Data Entries can be referenced either by:
 - If a SET
                entry is used to reference multiple RANDPS data, then the
                    RANDT1 entry with the smallest ID from set of referenced
                entries will be selected for the analysis.For example:
RANDOM=2 SET 2 = 5,6,7 BEGIN BULK $ RANDPS,5 RANDPS,6 RANDPS,7 $ RANDT1,5 → This RANDT1 entry is selected for analysis. RANDT1,6
