RANDPS
Bulk Data Entry Defines load set power spectral density factors for use in random analysis having the frequency dependent form .
| RANDPS | SID | J | K | X | Y | TID |
| RANDPS | 5 | 3 | 7 | 2.0 | 2.5 | 4 |
| SID | Random analysis set
                                identification number. (Integer > 0)  |
| J | Subcase identification
                                number of excited load set. (Integer > 0)  |
| K | Subcase identification
                                number of applied load set. (Integer > 0; K ≥ J)  |
| X, Y | Components of complex
                                    number. (Real)  |
| TID | A
                                    TABRNDi entry identification number which
                                defines G(F).
 Integer ≥ 0  |
- If J = K, then Y must be 0.0.
 - RANDPS Bulk Data
                Entries can be referenced either by:
- The RANDOM Subcase or Case Control Entry.
 - A SET I/O Options Entry that is then referenced by a RANDOM Case Control Entry.
 - A SET Bulk Data Entry with TYPE=MODE that is then referenced by a RANDOM Case Control Entry.
