PCONV
Bulk Data Entry Defines a free convection boundary condition properties.
| PCONV | PCONID | MID | FORM | EXPF | FTYPE | H1 |
| PCONID | Convection property identification
                  number of a PCONV card. No default (Integer > 0)  |
| MID | Material property identification
                  number of MAT4 card. (Integer > 0) Defaults: If FTYPE = 3, Default = Blank If FTYPE ≠ 3, No default  |
| FORM | Types of formula used for free
                  convection and, also to define the reference temperature definition for
                  temperature-dependent convection coefficient lookup. 3 If 0, 10, or 20, If 1, 11, or 21 Where, is grid temperature and is the ambient temperature. Default = 0 (Integer)  |
| EXPF | Free convection exponent. If FORM = 0, 10, or 20, EXPF = 0.0 for linear convection. If FORM = 1, 11, or 21, EXPF = 1.0 for linear convection. Therefore, linear convection formula is:  |
| FTYPE | Convection Coefficient definition
                    type.
 No default (Integer)  |
| H1 | Free Convection Coefficient value (for
                    FTYPE=3). Defines the Free Convection Coefficient value, if FTYPE=3. No default (Real ≥ 0.0)  |
- Every CONV card must refer a PCONV card.
 - Heat transfer coefficient (H) is specified on MAT4 card with MID.
 - In Nonlinear Heat Transfer, to define the
          reference temperature definition for temperature-dependent convection coefficient lookup,
          the FORM field can be used as:
- FORM
 - Reference Temperature Description
 - 0 or 1 (Default)
 - Reference Temperature is the average of:
- Element grid point temperatures (average), and
 - Ambient point temperatures (average)
 - 10 or 11
 - Reference temperature is the surface temperature (average of element grid point temperatures)
 - 20 or 21
 - Reference temperature is the ambient temperature (average of ambient point temperatures).
 - This card is represented as a group in HyperMesh.
