CONV
Bulk Data Entry Defines a free convection boundary condition for heat transfer analysis through connection to a surface element (CHBDYE card).
It can also used to define the ambient points for free convection, or for convection with fluid flow via CAFLUID entry.
| CONV | EID | PCONID | CNTRLND | TA |
| EID | CHBDYE
                                surface element identification number. No default (Integer > 0)  |
| PCONID | Convection property
                                identification number of a PCONV entry. No default (Integer > 0)  |
| CNTRLND | Control node for time
                                dependent convection coefficient. Default = 0 (Integer > 0)  |
| TAi | TAi
                                fields can be used to define one of the following:
- The basic exchange relationship is expressed as:
                        Where,
- Free convection heat transfer coefficient specified on a MAT4 entry, referred by a PCONV entry
 - Time-dependent multiplier provided by SPCD, which constrains node identified by CNTRLND field
 - Grid temperature
 - Ambient temperature
 - The time-dependent multiplier ( ) for the heat transfer convection coefficient is controlled via control nodes (CNTRLND field). The same nodes should be referenced on SPCD entries. Time-dependency is activated by referencing the corresponding SPCD entry on TLOAD1/TLOAD2 entries.
 - CONV is used with a CHBDYE entry having the same EID.
 - In linear steady-state heat transfer analysis, ambient temperature is specified by SPC of the TA point.
 - This card is represented as a secondary element in HyperMesh.
