Bulk Data Entry Defines the properties of 2D axisymmetric elements.
    Referenced by CTAXI and CQAXI entries.
                                                  | (1) |
                                                  (2) |
                                                  (3) |
                                                  (4) |
                                                  (5) |
                                                  (6) |
                                                  (7) |
                                                  (8) |
                                                  (9) |
                                                  (10) |
                                                  | PAXI |
                                                  PID |
                                                  MID |
                                                  | (1) |
                                                  (2) |
                                                  (3) |
                                                  (4) |
                                                  (5) |
                                                  (6) |
                                                  (7) |
                                                  (8) |
                                                  (9) |
                                                  (10) |
                                                  | PAXI |
                                                  2 |
                                                  203 |
                                                  | Field |
                                                  Contents |
                                                  SI Unit Example |
                                                  | PID |
                                                  Unique axisymmetric element property identification number. No default (Integer >
                  0)  |
                                                  | MID |
                                                  Identification number of a MAT1, MAT3 or MATHE
                  entry. No default (Integer > 0)  |
        - All axisymmetric element property entries must
          have unique ID numbers.
                                                 - This
          card is represented as a property in HyperMesh.
