MAT1
Bulk Data Entry Defines the material properties for linear, temperature-independent, and isotropic materials.
| MAT1 | MID | E | G | NU | RHO | A | TREF | GE | |
| ST | SC | SS | |||||||
| MODULI | MTIME | ||||||||
| RAYL | ALPHA | BETA | |||||||
| UDATA | PARAM1 | VALUE1 | PARAM2 | VALUE2 | etc. | ||||
| A | A1 | A2 | A3 | A4 | A5 | A6 | |||
| ESDAMP | ESD |
| SELECT | SELECTID | ||||||||
| + | E | G | NU | RHO | A | TREF | GE | ||
| + | etc. |
Example 1
| MAT1 | 17 | 3.+7 | 0.33 | 4.28 |
Example 2
| MAT1 | 17 | 3.+7 | 0.33 | 4.28 | |||||
| SELECT | 33 | ||||||||
| + | 5.0E+7 | 0.33 | 3.8 |
| MID | Unique material identification.
 No default (Integer > 0 or <String>)  |
| E | Young's modulus. Default = blank (Real or blank)  |
| G | Shear modulus. Default = blank (Real or blank)  |
| NU | Poisson's ratio. If < 0.0, a warning is issued. Default = blank (-1.0 < Real < 0.5 or blank)  |
| RHO | Mass density. Used to
                                automatically compute mass for all structural elements. No default (Real)  |
| A |
| Ai | Components of second order
                                thermal expansion coefficient tensor. (xx, yy, zz, xy, yz, zx)  |
| TREF | Reference temperature for
                                thermal loading. Default = 0.0 (Real)  |
| GE | Structural element damping
                                coefficient. 10
                                11 No default (Real)  |
| ST, SC, SS | Stress limits in tension,
                                compression and shear. 19 No default (Real)  |
| MODULI | Continuation line flag for moduli temporal property. 12 | |
| MTIME | Material temporal
                                property. This field controls the interpretation of the input
                                material property for viscoelasticity.
| RAYL | Continuation line flag for material-dependent Rayleigh damping. | |
| ALPHA | Material-dependent
                                Rayleigh Damping coefficient for the mass matrix.  Default = blank (Real ≥ 0.0)  |
| BETA | Material-dependent
                                Rayleigh Damping coefficient for the stiffness matrix.  Default = blank (Real ≥ 0.0)  |
| UDATA | Flag indicating that user-defined material parameters for storage through the workflow are to follow. 15 | |
| PARAMi | Name of the user-defined
                                material parameters for storage. Default = Blank (Alphanumeric string)  |
| VALUEi | Value of the corresponding
                                user-defined material parameters.  Default = Blank (Real)  |
| ESDAMP | Continuation line flag for strain energy proportional damping. 18 | |
| ESD | Damping coefficient used
                                for strain energy proportional damping 18.
                                     Default = Blank (Real ≥ 0.0)  |
| SELECT | Indicates that the subcase-dependent material definitions are to follow. | |
| SELECTID | Identification number of
                                the SELECT subcase-dependent definition.  No default (Integer > 0)  |
- The material identification number/string must be unique for all MAT1, MAT2, MAT8 and MAT9 entries.
 - String based labels allow for easier visual identification of materials, including when being referenced by other cards. (example, the MID field of properties). For more details, refer to String Label Based Input File in the Bulk Data Input File.
 - Either E or G must be specified (that is, non-blank).
 - If any one of E,
                        G, or NU is blank, it is computed to
                    satisfy the identity,
E = 2(1+NU)G; otherwise, values supplied by you are used.
 - If E and NU are both blank, they are both given the value 0.0.
 - If G and NU are both blank, they are both given the value 0.0.
 - Unlikely data on one or more
                        MAT1 entries result in a warning message. Unlikely data
                    is defined as:
- E < 0.0 or
 - G < 0.0 or
 - NU > 0.5 or
 - NU < -1.0 or
 - except for cases covered by comments 5 and 6.
 - It is strongly recommended that only two of the three values E, G, and NU be input.
 - The large field format may also be used.
 - To obtain the damping coefficient GE, multiply the critical damping ratio, by 2.0.
 - TREF and GE are ignored, if a MAT1 entry is referenced by a PCOMP, PCOMPP, or PCOMPG Bulk Data Entries.
 - MODULI continuation line is only applicable when used together with the MATVE entry. Refer to MATVE which provides additional information on how this material input is interpreted.
 - For material-dependent Rayleigh damping, the equivalent viscous
                    damping,
                        , is defined as:Where,
- and
 - Defined on the RAYL continuation line on the material entry
 - Mass matrix
 - Stiffness matrix
- Direct Frequency Response
 - Modal Frequency Response
 - Direct Transient Response
 - Modal Transient Response
 - Nonlinear Transient Analysis
 - Explicit Dynamic Analysis
Note: For cohesive elements that reference MAT1, material-based Rayleigh damping is only supported for Nonlinear Transient Analysis. - This card is represented as a material
                    in HyperMesh.
Element Type E NU G CROD, CBAR, CBEAM, and CWELD Axial and Bending N/A Transverse Shear and Torsion CSHEAR N/A N/A Shear CQUAD and CTRIA Membrane and Bending Membrane and Bending Transverse Shear CHEX, CTETRA, CPENTA, CPRYRA and CSEAM Deformation N/A  - User-defined parameters and their corresponding values can be stored on the UDATA continuation line. They are visible if the input file is echoed out (via the ECHO command). They are not used in the analysis.
 - The MAT1 data can be output to the HDF5 format (.h5 file) when a model that contains MAT1 also contains an HDF5 output request (either OUTPUT,HDF5,YES or result-specific HDF5 request such as DISP(HDF5)=ALL).
 - Orthotropic and anisotropic coefficients of thermal expansions can be defined for solid elements for implicit small displacement and large displacement analyses. This definition is available for MAT1 combined with all material Bulk Data Entries which share the same material ID with MAT1 for example, MATS1, MATVE, MATVP, etc.
 - The ESDAMP line can be used to define the material damping for strain energy proportional damping calculation. The output of strain energy proportional damping can be requested by OUTPUT, ESDAMP. If The ESD value is not defined, the material is not included in the calculation of the strain energy proportional damping.
 - The allowable stress fields SC, ST, or SS should be defined to output all failure criteria. If only ST is defined, only the Von Mises and Major Principal Stress Factor of Safety (FoS) are calculated. If SC is also defined, the Minor Principal Stress Factor of Safety (FoS) is also calculated. If only SS is defined, only the Tresca FoS is calculated. The allowable stress fields ST, SC, SS are used in the FAILURE Subcase Information Entry (referencing MAT1) to output all failure criteria.
