MBSFRCC
Bulk Data Entry Defines a curve scalar load on two grid points.
| MBSFRCC | SID | G1 | G2 | CVID | INT | EID |
| MBSFRCC | 3 | 345 | 346 | 1 | AKIMA | 1 |
| SID | Load set
                                    identification number. No default (Integer > 0)  |
| G1 | Grid point
| G2 | Grid point
| CVID | Set identification
                                    number of the MBCRV entry that gives the load
                                    versus independent variable measured in the coordinate system
                                    defined by CID. (Integer > 0)  |
| INT | Interpolation type.
 (Character)  |
| EID | Set identification
                                    number of the MBVAR for
                                    the independent variable expression. Default = TIME (Integer ≥ 0 or blank)  |
- MBSFRCC applies a translational action-reaction force along the line of action defined by the line segment connecting G1 and G2.
 - The action force is applied to G1 and the reaction force is applied to G2.
 - Tensile force is positive.
