Bulk Data Entry Defines a multibody solver variable which can be
        referred to by multiple expressions.
                            | (1) |
                            (2) |
                            (3) |
                            (4) |
                            (5) |
                            (6) |
                            (7) |
                            (8) |
                            (9) |
                            (10) |
                            | MBVAR |
                            VID |
                            EXPR |
                            | (1) |
                            (2) |
                            (3) |
                            (4) |
                            (5) |
                            (6) |
                            (7) |
                            (8) |
                            (9) |
                            (10) |
                            | MBVAR |
                            3 |
                            IMPACT(Dz(30301020,30302040),VZ(30301020,30302040),0.0,4 |
                            00,1.0,0.5,0.000) |
                                | Field |
                                Contents |
                                SI Unit Example |
                                | VID |
                                Variable
                                    identification number. (Integer > 0)  |
                                | EXPR |
                                Character string
                                    expression. The expression can spawn multiple lines. The
                                    continuation lines will start from the second column. Refer to
                                        Function Expressions. |
            - The variable ID can be referenced by
                    VARVAL(VID) in multiple expressions in the model.
