MBREQ
Bulk Data Entry Defines a multibody as a combination of request sets defined via MBREQE and MBREQM.
| MBREQ | SID | R | R | R | R4 | R5 | R6 | R7 | |
| R8 | R9 | etc |
| MBREQ | 3 | 31 | 34 | 35 |
| SID | Request set identification
                                    number. (Integer > 0)  |
| Ri | Request set identification
                                numbers defined via entry typed enumerated above. The
                                    Ri must be unique. (Integer > 0)  |
- Request sets must be selected in the Subcase Information section (REQUEST) if they are to be applied.
