FORMAT
I/O Options EntryThe FORMAT command can be used in the I/O Options section to indicate the format in which results are to be output.
FORMAT = option
| Argument | Options | Description |
| option | <ASCII, OS, OPTI, HM, HYPER, BOTH, H3D, FLX, NASTRAN, PUNCH, PATRAN, APATRAN, O2, OUT2, OP2, PLOT, NONE> |
- Information provided on OUTPUT entries takes precedence over information provided on FORMAT entries. If neither of these entries are defined, the output formats defined in the Configuration File are used. If a format is not defined by the OptiStruct configuration file, then both the HM and H3D formats are active by default.
 - Multiple FORMAT commands are allowed.
 - It is recommended to use the OUTPUT command instead of the FORMAT command since it is more flexible and allows different frequencies of output for different formats during an optimization.
 - format=OUTPUT2 can also be used to request results to be output in the Nastran output2 format (.op2 file).
