DVMREL2
Bulk Data Entry Relates design variables to an analysis model material property using a relationship defined by a DEQATN card. The equation inputs come from the referenced DESVAR values and constants defined on a DTABLE card.
| DVMREL2 | ID | TYPE | MID | MPNAME/FID | EQID | ||||
| DESVAR | DVID1 | DVID2 | DVID3 | DVID4 | DVID5 | DVID6 | DVID7 | ||
| DVID8 | DVID9 | etc. | |||||||
| DTABLE | LABL1 | LABL2 | LABL3 | LABL4 | LABL5 | LABL6 | LABL7 | ||
| LABL8 | etc. |
Example 1
To relate the Damping Coefficient value on a MAT1 card (field 9)
                to some user-defined relationship of design variables 5 and 6 and the table entry
                    GE0.
| DVMREL2 | 17 | MAT1 | 22 | 9 | 1 | ||||
| DESVAR | 5 | 6 | |||||||
| DTABLE | GE0 |
Example 2
This example is the same as , except that it defines MPNAME in place of
                    FID.
| DVMREL2 | 17 | MAT1 | 22 | GE | 1 | ||||
| DTABLE | GE0 |
Associated Cards
| DESVAR | 5 | GE1 | 1.0 | 2.0 | 0.5 | ||||
| DESVAR | 6 | GE2 | 1.0 | 1.0 | 0.01 | ||||
| DTABLE | GE0 | 0.01 | |||||||
| DEQATN | 1 | GE(GE1, GE2, GE0) = GE0+(GE1*GE2) | |||||||
| MAT1 | 22 | 2.1e5 | 0.3 | 7.85e-9 | 1.0 | ||||
| ID | Relationship
                                identification number. ID must be unique with respect to other
                                    DVMREL2 cards. No default (Integer > 0)  |
| TYPE | Material type to be
                                related (MAT1, MAT2, MAT4, MAT5, MAT8, MAT9, or MAT9OR). No default (Character)  |
| MID | Material identification
                                    number. No default (Integer > 0)  |
| MPNAME/FID | Material property name,
                                such as "E" or "RHO" (as in the documentation of the material Bulk
                                Data Entries), or field number on a material Bulk Data Entry. No default (Character or Integer > 0)  |
| EQID | Equation ID of
                                    DEQATN data. No default (Integer > 0)  |
| DESVAR | Indicates DESVAR ID numbers follow. | |
| DVID# | DESVAR
                                    ID. No default (Integer > 0)  |
| DTABLE | Indicates DTABLE labels follow. | |
| LABL# | Constant label. Must match
                                with a constant label of a DTABLE entry. No default (Character)  |
- See the DVMREL - Types section for details on the supported material fields and the MPNAME/FID entries.
