Job Manager
Use the Job Manager tool to interact with analysis jobs created through the NVH Director.
Click the Job Manager tool.Figure 1.
Job Manager Toolbar
| Job Import and Path Check | |
| Job Export | |
| Job Path Check | |
| Delete an existing job record | |
| Re-run a job | |
| Stop a running job | |
| Update the job list | |
| Select all jobs in the table | |
| De-select all jobs | |
| Select those jobs not previously selected | |
| Show the log window | |
| Opens the Filter jobs dialog |
Job Table
Provides a list of all of the jobs created as part of a project.
- Job Names
- Name of the analysis defined in the Analysis Manager.
- Job Number
- Job sequence ID.
- Job Submission server
- Server to which the job was submitted to.
- Application
- Solver that was used to perform the analysis.
- Job Directory:
- This is typically the directory where the input .xml file is located.
- Input File Name
- NVH Director model .xml file.
- Status
- Job completion status.
- Created Date
- The date a job was created or modified.
Job Details
Provides a record of why each job was run, and how the model was set up. There is also an
option to add/edit the job description.Figure 4.
Result Files
Provides easy access to result files generated in each job by the solver. Figure 5.
