Create LSP Load Cases From a Load Combination File
In addition to creating linear superposition load cases manually, you can also input a load combination file which will automatically create them for you.
                From the Home tools, click the Loadcase satellite tool.
                In the dialog, click
 and
                    browse for a load combination file (.lcf) that contains the
                    details of the fatigue load case combinations.
                Click
 to import the file.
#PARAM and should contain
            the following data in the sequence mentioned below:- An
#LCBAStag to indicate the start of base load case definitions. - Base load case data that are to be used in HyperLife Crack Growth – first the ID and then the name, as in the example below. It's required to specify the base load cases for HyperLife Crack Growth to understand which bases cases are used in combinations.
 - An
#LCtag to indicate the start of the load combination data. - Load combination data, as shown in the example below.
