UNITS
I/O Options and Subcase Information Entry The UNITS command can be used in the I/O Options section to define a system of units for the model.
UNITS = system
| Argument | Options | Description |
| system | <SI,
                                    CGS, MPA,
                                    BG> No default  |
- Multiple instances of this card are allowed. If instances are conflicting, the last instance dominates.
 - This UNITS Data Entry is the same as the DTI,UNITS entry.
