Bulk Data Entry Defines units for multibody, component mode
        synthesis (flexible-body preparation), and Explicit Dynamic Analysis sequences.
        | (1) |
        (2) |
        (3) |
        (4) |
        (5) |
        (6) |
        (7) |
        (8) |
        (9) |
        (10) |
| DTI |
UNITS |
1 |
MASS |
FORCE |
LENGTH |
TIME |
                           | (1) |
                           (2) |
                           (3) |
                           (4) |
                           (5) |
                           (6) |
                           (7) |
                           (8) |
                           (9) |
                           (10) |
                            | DTI |
                            UNITS |
                            1 |
                            KG |
                            N |
                            M |
                            S |
                            | Field |
                            Contents |
                            SI Unit Example |
                            | MASS |
                            Units of mass. 3
                                        - kg (Default)
                                        - kilogram
                                        - lbm
                                        - pound-mass
                                        - slug
                                        - slug
                                        - gram
                                        - gram
                                        - ozm
                                        - ounce-mass
                                        - klbm
                                        - kilo pound-mass (1000.lbm)
                                        - mgg
                                        - megagram
                                        - slinch
                                        - 12 slugs
                                        - ug
                                        - Microgram
                                        - ng
                                        - Nanogram
                                        - uston
                                        - US ton
                                        - mg
                                        - Milligram
                            | FORCE |
                            Units of force. 3
                                        - n (Default)
                                        - newton
                                        - lbf
                                        - pounds-force
                                        - kgf
                                        - kilograms-force
                                        - ozf
                                        - ounce-force
                                        - dyne
                                        - dyne
                                        - kn
                                        - kilonewton
                                        - klbf
                                        - kilo pound-force (1000.lbf)
                                        - mn
                                        - Millinewton
                                        - un
                                        - Micronewton
                                        - nn
                                        - Nanonewton
                            | LENGTH |
                            Units of length. 3
                                        - mm (Default)
                                        - millimeter
                                        - km
                                        - kilometer
                                        - m
                                        - meter
                                        - cm
                                        - centimeter
                                        - mi
                                        - mile
                                        - ft
                                        - foot
                                        - in
                                        - inch
                                        - um
                                        - Micrometer
                                        - nm
                                        - Nanometer
                                        - ang
                                        - Angstrom
                                        - yd
                                        - yard
                                        - mil
                                        - Milli-inch
                                        - uin
                                        - Micro-inch
                            | TIME |
                            Units of time.  3
                                        - s (Default)
                                        - seconds
                                        - h
                                        - hours
                                        - min
                                        - minutes
                                        - ms
                                        - milliseconds
                                        - us
                                        - Microsecond
                                        - nanosec
                                        - Nanosecond
                                        - d
                                        - day
            - PARAM, WTMASS is ignored for the
                    multibody and component mode synthesis (flexible-body preparation) solution
                    sequences. Unit data for these solution sequences is supplied on the
                        DTI,UNITS Bulk Data Entry.
            - This DTI,
                        UNITS Data Entry is the same as the UNITS entry.
            - If the units defined on the
                        DTI,UNITS entry are not consistent,
                    mass unit is ignored, only force, length, and time units are considered in
                    Explicit Dynamic Analysis subcases.
            - This card is represented as a control
                    card in HyperMesh.
