PLY
Bulk Data Entry Defines the properties of a ply used in ply-based composite definition.
| PLY | ID | MID | T | THETA | SOUT | TMANUF | DID | ||
| ESID1 | ESID2 | ESID3 | ESID4 | ESID5 | ESID6 | ESID7 | ESID8 | ||
| ESID9 | etc. |
| PLY | 1 | 2 | 0.1 | 45 | YES | 0.01 | |||
| 1 |
| ID | Unique ply identification.
 No default (Integer > 0 or <String>)  |
| MID | Material identification number. Must
                  refer to a MAT1, MAT2 or MAT8 Bulk Data Entry. No default (Integer > 0)  |
| T | Ply thickness. No default (Real > 0.0)  |
| THETA | Ply orientation angle, in degrees, of
                  the longitudinal direction relative to the x-axis of the material coordinate
                  system associated with a given element. If no material coordinate system is
                  specified for the element, the angle is measured relative to side 1-2 of this
                    element. Default = 0.0 (Real or blank)  |
| SOUT | Stress, Strain, and Failure Index
                  output request. 2
                  3
| TMANUF | Thickness of one manufacturable ply.
                  Defines the thickness of one manufacturable ply. This parameter is used during
                  sizing optimization to automatically create discrete design variables such that
                  the thickness of the ply bundle is equal to a multiple of
                    TMANUF. Default = blank (Real or blank)  |
| DID | Draping identification number. Must
                  refer to a DRAPE Bulk Data Entry. Default = blank (Integer > 0)  |
| ESID# | Element SET
                  identification numbers. Lists the elements for which this PLY
                  card is defined. A minimum of one ESID# should be specified. No default (Integer > 0)  |
- The PLY card is used in combination with the PCOMPP and STACK cards to create composite properties through the ply-based definition.
 - Stress, Strain and Failure Index output for the PLY is activated by setting SOUT to YES. In addition, the CFAILURE I/O Option should be defined. Failure Index output for PLY's also requires that the FT and SB fields be defined on the corresponding PCOMPP entries, and that stress/strain allowables on the referenced materials are defined.
 - An additional piece of information available with ply results is "failure index for the element," which is the maximum of failure indices for individual plies in this element. Only the plies with SOUT set to YES are considered in the evaluation of this maximum.
 - String based labels allow for easier visual identification of ply entries, including when being referenced in the PLYID# field of STACK entries. For more details, refer to String Label Based Input File in the Bulk Data Input File.
 - This card is represented as a ply in HyperMesh.
