MAT2
Bulk Data Entry Defines the material properties for linear, temperature-independent, and anisotropic materials for two-dimensional elements.
Attention: Valid for Implicit
                    and Explicit Analysis
| MAT2 | MID | G11 | G12 | G13 | G22 | G23 | G33 | RHO | |
| A | A | A12 | TREF | GE | ST | SC | SS | ||
| RAYL | ALPHA | BETA |
| MAT2 | 13 | 6.2+3 | 6.2+3 | 5.1+3 | 0.056 | ||||
| 6.5-6 | 6.5-6 | -500.0 |
| MID | Unique material identification.
 No default (Integer > 0 or <String>)  |
| Gij | Material property
                                    matrix. No default (Real)  |
| RHO | Mass density. Used to
                                automatically compute mass for all structural elements. No default (Real)  |
| Ai | Thermal expansion
                                coefficient vector. No default (Real)  |
| TREF | Reference temperature for
                                the calculation of thermal loads. Data from the
                                    MAT2 entry is used directly, without
                                adjustment of equivalent E, G,
                                or NU values. Default = blank (Real or blank)  |
| GE | Structural element damping
                                coefficient. 9
                                10 No default (Real)  |
| ST, SC, SS | Stress limits in tension,
                                compression and shear. Used for composite ply failure
                                    calculations. No default (Real)  |
| RAYL | Continuation line flag for material-dependent Rayleigh damping. | |
| ALPHA | Material-dependent
                                Rayleigh Damping coefficient for the mass matrix.  Default = blank (Real ≥ 0.0)  |
| BETA | Material-dependent
                                Rayleigh Damping coefficient for the stiffness matrix.  Default = blank (Real ≥ 0.0)  |
- The material identification number/string must be unique for all MAT1, MAT2, MAT8 and MAT9 entries.
 - String based labels allow for easier visual identification of materials, including when being referenced by other cards. (example, the MID field of properties). For more details, refer to String Label Based Input File in the Bulk Data Input File.
 - The mass density, RHO, is used to automatically compute mass for all structural elements.
 - The convention for the Gij
                    in fields 3 through 8 is represented by the matrix relationship:
 - If this entry is referenced by the MID3 field (transverse shear) on the PSHELL, G13, G23, and G33 must be blank.
 - Unlike the MAT1 Bulk Data Entry, data from a MAT2 Bulk Data Entry is used directly, without adjustment of equivalent E, G, or NU values.
 - TREF is used as the reference temperature for the calculation of thermal loads.
 - The long field format may be used.
 - To obtain the damping coefficient GE, multiply the critical damping ratio, by 2.0.
 - TREF and GE are ignored, if a MAT2 entry is referenced by a PCOMP entry.
 - If a MAT2 card is pointed to by a MID4 on PSHELL, and has a material ID greater than 400,000,000, then the thermal membrane-bending coefficients A, A, and A12 have a modified interpretation, and represent [G]*[alpha], rather than [alpha]. Here, [G] is a matrix composed of G11, G22, through, G33. This is to maintain consistency with respective terms generated internally by the PCOMP card.
 - For material-dependent Rayleigh damping, the equivalent viscous
                    damping,
                        , is defined as:Where,
- ALPHA and BETA
 - Defined on the RAYL continuation line on the material entry
- Mass matrix
 - Stiffness matrix
- Direct Frequency Response
 - Modal Frequency Response
 - Direct Transient Response
 - Modal Transient Response
 - Nonlinear Transient Analysis
 - Explicit Dynamic Analysis
 - This card is represented as a material in HyperMesh.
