PELASFX
Bulk Data Entry Used to define the stiffness and stress coefficient of a scalar elastic element (spring) by means of the CELAS1 or CELAS3 entry.
This property is not affected by translational and rotational stiffness limits specified using PARAM,ELASSTIF.
PELASFX PID K GE S PID K GE S
PELASFX 7 4.29 7.92 27 2.17
PID Unique scalar elastic property identification number.
No default (Integer > 0)
K Elastic property value.
No default (Real)
GE Damping coefficient. To obtain the damping coefficient GE, multiply the critical damping ratio, C/C0 , by 2.
GE is ignored in transient analysis, if PARAM, W4 is not specified.
Default = 0.0 (Real)
S Stress coefficient.
  1. Be careful using negative spring values.
  2. One or two elastic spring properties may be defined on a single entry.
  3. The element force of a spring is calculated from the equation:
    f=k*(u1u2)
    Where,
    k
    Stiffness coefficient for the scalar element.
    u1
    Displacement of the first degree-of-freedom listed on the CELAS1 and CELAS3 entries.
    Element stresses are calculated from the equation:
    s=S*f
    Where, S is the stress coefficient as defined above.
  4. This card is represented as a property in HyperMesh.
