CELAS3
Bulk Data Entry Defines a scalar spring element that connects only to scalar points.
| CELAS3 | EID | PID | S1 | S2 |
| CELAS3 | 19 | 2 | 14 | 15 |
| EID | Unique element
                                identification number. No default (Integer > 0) | |
| PID | A PELAS property entry
 Default = EID (Integer > 0 or <String>) | |
| S1, S2 | Scalar point
                                identification numbers. S1 or S2 may be blank or zero indicating a constrained coordinate. Default = 0 (Integer ≥ 0; S1 ≠ S2) |
- Only one scalar spring element may be defined on a single entry.
- A scalar point specified on this entry does not need to be defined on a SPOINT Bulk Data Entry.
- String based labels allow for easier visual identification of properties, when being referenced by the elements cards. For more details, refer to String Label Based Input File in the Bulk Data Input File.
- This card is represented as a spring or mass element in HyperMesh.
