MBMNTC
Bulk Data Entry Defines a curve moment at a grid point by specifying a vector.
MBMNTC SID G1 CID CVID G3/N N N G2
INT EID
MBMNTC 3 345 4 0.0 1.0 0.0
AKIMA 42
SID Load set identification number.
No default (Integer > 0)
G1 Grid point identification number where the action force is applied.
CID Coordinate system identification number. Blank or 0 infer the basic coordinate system.
Default = 0 (Integer ≥ 0, or blank)
CVID Set identification number of the MBCRV entry that gives the load versus independent variable measured in the coordinate system defined by CID.
(Integer > 0)
G3 Grid point identification number to optionally supply N1, N2, N3 in conjunction with G1.
(Integer > 0)
N,N,N Defines the direction of the force vector. At least one of the vector components must be non-zero.
Default = 0.0 (Real)
G2 Grid point identification number where the reaction force is applied. If blank or zero, then the force is an action-only force.
Default = 0 (Integer ≥ 0)
INT Interpolation type.
AKIMA (Default)
CUBIC
LINEAR
(Character)
EID Set identification number of the MBVAR for the independent variable expression.
Default = TIME (Integer ≥ 0 or blank)
  1. This card is represented as a moment load in HyperMesh.
