MBVAR
Bulk Data Entry Defines a multibody solver variable which can be referred to by multiple expressions.
MBVAR | VID | EXPR |
MBVAR | 3 | IMPACT(Dz(30301020,30302040),VZ(30301020,30302040),0.0,4 | |||||||
00,1.0,0.5,0.000) |
VID | Variable
identification number. (Integer > 0) |
EXPR | Character string expression. The expression can spawn multiple lines. The continuation lines will start from the second column. Refer to Function Expressions. |
- The variable ID can be referenced by VARVAL(VID) in multiple expressions in the model.
