MATF
Bulk Data Entry Defines material properties and failure model parameters for Failure criteria calculations.
Format A - Implicit
MATF | MID | ||||||||
CRI | CRITERIA | TID/V1 | V2 | V3 | V4 | V5 | V6 | ||
V7 | V8 | V9 | V10 | V11 | V12 | W1 | |||
W2 | W3 | W4 | |||||||
etc. |
Format B - Explicit
MATF | MID | DAMAGE | DC | EXP | LENDT | PFAIL | |||
CRI | CRITERIA | EPS_TID/ MATER/ INI_ID/V1 | V2/EVO_ID | V3 | V4 | V5 | V6 | ||
INST_ID | V7 | V8 | V9 | ||||||
DEP_L | E_TID | EL_REF | FE_SCL | ||||||
DEP_SR | V_TID | V_REF | VT_SCL | JC |
Example A
MATF | 100 | ||||||||
CRI | PUCK | 3.E5 | 3.E5 | 3.E5 | 3.E5 | 3.E5 | |||
0.25 | |||||||||
0.25 | 0.25 |
Example B.1 (Non-linear partially coupled BIQUAD criterion with classic input)
MATF | 1 | DAMAGE | 0.2 | 2.0 | LENDT | ||||
CRI | BIQUAD | 1.5 | 0.25 | 0.35 | 0.09 | 0.12 | |||
0.045 |
Example B.2 (Coupled equivalent strain TSTRN criterion with strain-rate dependency)
MATF | 1 | DAMAGE | 0.0 | 1.0 | |||||
CRI | TSTRN | 0.05 | 50.0 | ||||||
DEP_SR | 9 | 2.1 | 1.5 |
Example B.3 (Coupled TAB criterion with controlled necking and element size dependency)
MATF | 1 | DAMAGE | 0.0 | 2.5 | LENDT | ||||
CRI | TAB | 36 | 1.0 | 2.0 | |||||
36 | 0.5 | -0.33 | 0.66 | ||||||
DEP_L | 9 | 5.2 | 0.8 |
Example B.4 (Failure indicator using material BIQUAD criterion input)
MATF | 1 | ||||||||
CRI | BIQUAD | MILD | 0.3 |
Example B.5 (Failure using INIEVO criterion with DMGINI and DMGEVO entries)
MATF | 1 | ||||||||
CRI | INIEVO | 36 | 37 | ||||||
Example B.6 (Maximum plastic strain criterion with element deletion and strain rate dependency)
MATF | 1 | DAMAGE | 1.0 | ||||||
CRI | PLAS | 0.35 | |||||||
DEP_SR | 9 | 2.1 | 1.5 | ||||||
Example B.7 (Johnson-Cook criterion with element deletion and strain rate dependency)
CRI | JOHNSON | 0.135 | 2.99 | 6.3 | |||||
MID | Material identification
number. (Integer > 0) |
CRI | Flag to indicate that the failure criterion input data are to follow. 3 | |
CRITERIA | Character String
representing the chosen failure criterion.
No default |
TID | Identification number of a TABLEMD entry that identifies the equivalent plastic strain (Yi) at the onset of damage versus temperature (Xi). 6 | |
Vi | Material limits. 1, 2 (Real) |
Wi | Parameters for failure
criteria calculations. 3
(Real > 0.0) |
DAMAGE | Flag to activate element
deletion and stress softening. 2, 8 By default, damage is only used as an output variable. Default = blank |
DC | Critical damage value from
which the stress softening is triggered. This is valid only if
DAMAGE is activated. 2, 8
EXP | Nonlinear exponent for
stress softening. This is valid only if DAMAGE is
activated. 2, 8 Default = 1.0 (Real) |
LENDT | Optional keyword to choose element characteristic length
formulation.
PFAIL | Percentage of failed integration points prior to element deletion.
Default = 1.0 (0 < Real < =1) |
EPS_TID | For
CRI=TAB. TABLEMD ID defining plastic strain at failure evolution with stress triaxiality and lode parameter. No default (Integer) |
MATER | For
CRI=BIQUAD. Character string selector for partially automatic parameter setup. This is optional and can be used when material data is unavailable. Note: It is still recommended to provide at
least c3 for accurate calculation.
INST_ID | For
CRI=TAB. TABLEMD ID defining plastic strain at necking instability evolution with stress triaxiality and Lode parameter. Default = blank (Integer) |
DEP_L | Flag to activate element
size dependency. 4 No default |
E_TID | (Optional)
TABLEMD ID for tabulated element size
dependency. Default = blank (Integer) |
EL_REF | Reference element
size. Default = blank or 1.0 (when E_TID is defined (Real) |
FE_SCALE | Scale factor for element
size dependency table. This affects the rate of increase or decrease of values defined in the table. Default = blank or 1.0 (when E_TID is defined) (Real) |
DEP_SR | Flag to activate strain rate dependency. 3 | |
V_TID | TABLEMD
ID for strain rate dependency. Default = blank (Integer) |
V_REF | Reference strain
rate. Default = 1.0 (Real) |
VT_SCALE | Scale factor for strain
rate dependency table. This affects the rate of increase or decrease of values defined in the table. Default = 1.0 (Real) |
JC | Johnson-Cook strain rate
dependency factor. Default = 0.0 (Real) |
INI_ID | For
CRI=INIEVO. 7 ID of the DMGINI Bulk Data Entry. |
EVO_ID | For
CRI=INIEVO ID of the DMGEVO Bulk Data Entry. Default = blank (Integer) |
- MID field may refer to MAT1, MAT2, MAT8, MAT9 or MAT9OR entries.
- Support information for various failure
criteria:
Analysis Type Supported Criteria Implicit Analysis (Linear and Nonlinear (SMDISP/LGDISP) Static/Transient) Analysis) PUCK, HILL, HOFF, TSAI, HASH, STRN, STRS, DUCTILE, PUCK3D, HILL3D, HOFF3D, TSAI3D, HASH3D, STRN3D, STRS3D, CNTZ3D Explicit Dynamic Analysis BIQUAD, TSTRN, TAB, INIEVO, PLAS - Multiple different failure criteria can be defined on a single MATF Bulk Data Entry. Therefore, the CRI continuation line can be repeated, and multiple different failure criteria can be specified. However, a particular failure criterion can only appear once on the MATF entry and cannot be repeated. Different failure criteria for different materials can be defined by referencing the corresponding material entry (with the same ID as MATF) on MID# fields of the PCOMP(G) and PLY entries (for PCOMPP). If different failure criteria are required to be defined for a single composite property, then the MATF entry should be used.
Comments: Format A
- For laminated shells
(PCOMP/PCOMPP/PCOMPG).V1, V2, through V5 specify material stress/strain limits.
- V1
- Tensile stress/strain limit in longitudinal direction
- V2
- Compressive stress/strain limit in longitudinal direction
- V3
- Tensile stress/strain limit in lateral direction
- V4
- Compressive stress/strain limit in lateral direction
- V5
- In-plane shear stress/strain limit
For STRS failure criterion, the input allowables should be stress-allowables.
For STRN failure criterion, the input allowables should be strain-allowables. OptiStruct will not conduct internal conversion for STRN failure criterion. The values defined are directly used as strain-allowables for STRN failure criterion on MATF.
For STRN failure criterion, the STRN field on MAT8 entry has no effect on the allowable values defined on the MATF entry.
For Solid Elements (MAT9/MAT9OR) and Continuum Shells (PCOMPLS).
V1, V2 through V9 specify material stress/strain limits.- V1
- Tensile stress/strain limit in 1-1 direction
- V2
- Compressive stress/strain limit in 1-1 direction
- V3
- Tensile stress/strain limit in 2-2 direction
- V4
- Compressive stress/strain limit in 2-2 direction
- V5
- Tensile stress/strain limit in 3-3 direction
- V6
- Compressive stress/strain limit in 3-3 direction
- V7
- Shear stress/strain limit in 1-2 direction
- V8
- Shear stress/strain limit in 2-3 direction
- V9
- Shear stress/strain limit in 1-3 direction
Coordinate system 1-2-3 are user-defined for continuum shell elements or solid elements with MAT9.
For STRS3D failure criterion, the input allowables should be stress-allowables.
For STRN3D failure criterion, the input allowables should be strain-allowables. OptiStruct will not conduct internal conversion for STRN3D failure criterion. The values defined are directly used as strain-allowables for STRN3D failure criterion on MATF.
- V10,
V11, and V12 are used for
TSAI/TSAI3D criterion.
- For TSAI:
- V10: the coupling coefficient C12 for the σ1σ2 term.
- If V10 is blank, the coupling coefficient is calculated from W1.
- If V10 and W1 are both blank, the coupling coefficient is 0.0.
- For TSAI3D:
- V11: the coupling coefficient C23 for the σ2σ3 term.
- V12: the coupling coefficient C12 for the σ1σ3 term.
- If V10, V11, and V12 are all blank, the coupling coefficients are calculated from W1, W2, and W3.
- If V10, V11, and V12 and W1, W2, and W3 are all blank, the coupling coefficients are 0.0.
- For TSAI:
- W1,
W2, W3, and W4
definition is dependent on the failure criterion specified.
- PUCK/PUCK3D specify failure
envelope parameters:
- W1
- Failure envelope factor 12(-)
- W2
- Failure envelope factor 12(+)
- W3
- Failure envelope factor 22(-)
- W4
- Failure envelope factor 22(+).
- TSAI3D on anisotropic solid material
If V10, V11 and V12 are blank, they are the tensile stress limits in equal-biaxial tension tests. W1 is the tensile stress limit in equal-biaxial tests where the two tensile loads are in directions 1 and 2. W1 is mandatory, while W2 and W3 are optional. If W2 and W3 are not specified, then they are set equal to W1. The definition of W2 and W3 is similar to W1. W2 is the tensile stress limit in equal-biaxial tension tests where the two tensile loads are in directions 2 and 3. W3 is the tensile stress limit in equal-biaxial tension tests where the two tensile loads are in directions 1 and 3.
If V10, V11 and V12 are defined, W1, W2 and W3 are ignored for TSAI3D.
- HASH3D
When Hashin failure criteria is applied on continuum shell elements, W1 is defined as alpha, which takes the transverse shear stress (in 1-2 and 1-3 direction) into account in the tensile fiber check. When W1 is blank, alpha is assumed to be 1.0.
- CNTZ3D
When using Cuntze failure criterion, W1 and W2, corresponding to the two free curve parameters, b⊥|| and bT⊥ should be provided. The two curve parameters can be determined from multi-axial test data from experiments. Bounds on the safe side for GFRP, CFRP and AFRP are assumed by Cuntze 1 to be:
0.0.5<b⊥|| <0.15, 1.0<bT⊥|<1.6
- When some failure criteria are
defined on both PCOMP(G/P) (allowables on
MATi) and MATF, then:
- If the same criterion type is defined in both PCOMP(G/P) property and the MATF entry, then the allowables defined on the MATF entry will be used in the failure criterion calculations. The MATF entry overwrites the allowables defined by the corresponding MATi entry (if any).
- If some criteria are only defined on PCOMP(G/P) but not on MATF, then for such criteria, the allowables are taken from corresponding MATi entries.
- If some criteria are defined on MATF, and PARAM,ALLFT,YES exists, then the criteria defined on MATF will use the allowables defined on MATF. However, the criteria not defined on MATF will be calculated based on allowables defined on the corresponding MATi entry.
- The following criteria can only be
PUCK, DUCTILE, PUCK3D, HILL3D, HOFF3D, TSAI3D, HASH3D, STRN3D, and CNTZ3D.
The rest of the criteria can also be defined on the FT field of the corresponding PCOMPP/PCOMPG/PCOMP entry.
For the PUCK failure criterion, even though it is available on the FT field of the PCOMPP/PCOMPG/PCOMP entry, the corresponding failure envelope factors (W1, W2, W3) can only be defined on the MATF entry. Therefore, the MATF entry is mandatory when PUCK failure criterion is requested via the FT field of PCOMP/PCOMPG/PCOMPP entries, and additionally, the allowables should be defined on the MATF for PUCK criterion only. To use PUCK failure criteria, the MATF entry should be specified with MID referring to the corresponding material entry.
- If the CRITERIA
field is set to DUCTILE, then the TID
field should point to a TABLEMD entry with
NDEP set to 1. The first data column
(Yi) is the equivalent plastic strain at the onset of
damage. The second data column (Xi) is the corresponding
temperature. The second column should be specified in ascending order only.
When the CRITERIA field is set to DUCTILE in OSTTS analysis, the temperature-based lookup is conducted for each temperature to identify the corresponding equivalent plastic strain from the TABLEMD entry. This plastic strain is used in conjunction with the calculated von Mises strain to calculate Damage (This can be output using the DAMAGE I/O Options Entry).
- The following tables summarize the
supported failure criteria with different properties and materials.
Table 1. Shell Elements PSHELL PCOMP/PCOMPG/PCOMPP MAT1/MAT2/MAT8 HILL No Yes HOFF No Yes TSAI No Yes STRN No Yes STRS No Yes HASHIN No Yes PUCK No Yes DUCTILE No Yes Table 2. Solid Elements PSOLID PCOMPLS MAT9 MAT9OR MAT9 MAT9OR HILL3D Yes Yes Yes Yes HOFF3D Yes Yes Yes Yes TSAI3D Yes Yes Yes Yes STRN3D Yes Yes Yes Yes STRS3D Yes Yes Yes Yes HASH3D No Yes Yes Yes PUCH3D No Yes Yes Yes CNTZ3D No Yes Yes Yes
Comments: Format B
- The usage of V1 through V8 in
difference criteria for Explicit Dynamic Analysis (Format B) is as
follows:
Vi BIQUAD TSTRN TAB PLAS JOHNSON V1 - von Mises equivalent strain at which damage starts (eps_es) Scale factor for the EPS_TID table Maximum plastic strain value. First Johnson-Cook parameter D1. V2 Failure plastic strain c1 in simple compression von Mises equivalent strain at which damage ends (eps_ee) n exponent for the damage variable evolution Critical Thinning Strain (EPS_THIN): > 0.0: Total Thinning Strain
< 0.0: Plastic Thinning Strain.
First Johnson-Cook parameter D2. V3 Failure plastic strain c2 in pure shear Major equivalent strain at which damage starts (eps_p1) - Critical Major Strain (EPS_MAJ) First Johnson-Cook parameter D3. V4 Failure plastic strain c3 in simple tension Major equivalent strain at which damage ends (eps_p2) - V5 Failure plastic strain c4 in plane strain - - V6 Failure plastic strain c5 in biaxial tension - - V7 Necking instability plastic strain in plane strain - Scale factor for INST_TID table V8 - - Stress triaxiality lower bound for element size regularization V9 Stress triaxiality upper bound for element size regularization - When the DAMAGE
keyword is activated, the stress softening effect is defined
by:σ=σeff[1−[D−DC1−DC]EXP]Where,
- σ
- Damaged stress tensor
- σeff
- Undamaged effective stress tensor
- D
- Damage variable
- If DC=0 , the stress softening starts as soon as D≠0 and the stress softening is fully coupled (blue curve in Figure 1).
- If 0<DC<1 , the stress softening is partially coupled as it starts when D=DC (red curve).
- If DC=1 , the stress tensor rapidly drops to 0 when D=1 and a failure criterion approach is then obtained (green curve).
Figure 1. Effect of stress softening parameter DC on a single element behavior in uniaxial tension Figure 2. Effect of stress softening exponent EXP on a single element behavior in uniaxial tension Note: If the DAMAGE keyword is not specified, the damage variable only becomes an output variable without triggering any element deletion of effect on stress computation. It can only show the critical spots of a structure where cracks are more likely to initiate. - The DEP_SR flag
can be used to introduce a strain rate dependency on the element failure.
This makes the material’s ductility dependent on the loading velocity. Two
possibilities are offered:
- If V_TID is defined, a tabulated strain rate
dependency is defined by TABLEMD, which defines
the evolution of a dimensionless factor denoted by
fsr(˙εε0)
evolution with strain rate. Then the
strain rate effect is introduced in the damage variable evolution by
multiplication with the plastic strain at failure:D=∞∑t=0Δεpεfp(η,ξ).fsr(˙εε0).fsrscaleWhere,
- η
- ξ
- Lode parameter
- ˙ε0
- V_REF
- fscalesr
- VT_SCALE
- εfp
- Plastic strain at failure
- ˙ε
- Strain rate
- If a continuous and analytical formula is desired, the Johnson-Cook
strain rate dependency can be set up by specifying only a reference
strain rate V_REF and the parameter JC (denoted
as in the equation). Then, the damage variable evolution is given
by:D=∞∑t=0Δεpεfp(η,ξ).(1+CJC〈ln˙εε0〉+)Note: The strain-rate computation (total equivalent or plastic strain rate) depends on the choice made in the MATS1 Bulk Data Entry. In the absence of plasticity, the strain-rate dependency is not available.
fsr(˙εε0)
- The DEP_L flag
can be used introduce a mesh size dependency that can define the element’s
ductile behavior dependent on its initial size. This can help to reduce the
well-known mesh size dependency encountered when using coupled damage models
or failure criteria. The TABLEMD defined in
E_TID defines the evolution of a dimensionless scale
factor with the initial element size given by,
fsize(L0eLref)
. The damage evolution then
becomes:D=∞∑t=0Δεpεfp(η,ξ)⋅fsize(L0eLref)⋅fscalesizeWhere,
- Lref
- EL_REF
- fscalesize
- FE_SCALE
- Both strain rate dependency and element size dependency can be used at the same time without creating any conflict.
- Element deletion from the mesh is
activated differently depending on the element type (solid or shell) and the
formulation (under-integrated or fully integrated).
- For solid elements, deletion occurs only if all the integration points fail.
- For shell elements, deletion occurs if more than half of the integration points (over thickness) fail.
- Damage initiation and evolution failure criterion (INIEVO) can also be defined using the DAMAGE continuation line in the MATS1 Bulk Data Entry.
- For the INIEVO criterion, strain rate dependency and element size dependency are not available as they are already considered through the DMGINI and DMGEVO Bulk Data Entries. The DAMAGE keyword, DC and EXP parameters are ignored for this criterion only. Element deletion is always turned on and stress softening is entirely controlled by the DMGEVO entry, if defined. If the DMGEVO entry is not specified, a failure criterion approach is used, and the element is deleted when the damage initiation criterion defined by the DMGINI entry is reached.
- PLAS failure criterion allows to define three different types of failure
criteria (that can be cumulated or used independently):
Failure based on a constant maximum plastic strain value at failure εfp . No stress triaxiality or Lode parameter dependency is considered here. The damage variable evolution is computed as:
D=∞∑t=0ΔεpεfpFailure based on thinning strain denoted as <Ezz> and only considered when <Ezz < 0>. This thinning strain is compared to a critical value denoted as <Ef_thin>. Depending on the input value sign, it can either correspond to a total strain or a plastic strain. The damage variable is then computed as:
D=∞∑t=0ΔεpεfpFailure based on major strain. The maximal positive value of the principal strains is compared to a critical value denoted by <Ef_maj>. The damage variable is then computed with:
D=∞∑t=0ΔεpεfpIf multiple failure types are used in PLAS, the maximal damage value is retained.
- Element reference length
Lref
used for element size dependency or damage
evolution in INIEVO criterion can be computed in two different ways:If LENDT is not specified:
- Lref=√A
- For shells where A is the area.
- Lref=3√V
- For solids where V is the volume.
If LENDT is specified:
Lref is the characteristic length used to compute the elementary critical timestep.
- Johnson-Cook (JOHNSON) criterion is
a very common solution used for elasto-plastic material failure accounting
for stress triaxiality effect. It considers an exponential decrease of the
material ductility with the increaing stress triaxiality. The obtained
damage evolution is given by:D=∞∑t=0Δεpεfp(η) with εfp(η)=D1+D2exp(−D3η)
Where D1, D2, and D3 are Johnson-Cook parameters. If a strain rate dependency is used, you can introduce the Johnson Cook strain rate dependency factor. In this case, the plastic strain at failure expression is:
εfp(η,˙ε)=(D1+D2exp(−D3η))(1+CJC〈log(˙ε˙εref)〉+) - For more information, refer to Material Failure Criterion in the Explicit Dynamic Analysis section of the User Guide.
