DMGINI
Bulk Data Entry Defines the damage initiation criteria.
Format I (CRI=MAXE, MAXS, QUADE, or QUADS)
DMGINI | DMGINIID | CRI | FLAT | ||||||
V1_1 | V2_1 | V3_1 | X1 | ||||||
V1_2 | V2_2 | V3_2 | X2 | ||||||
V1_3 | V2_3 | V3_3 | X3 | ||||||
etc. | etc. | etc. | etc. |
Format II (CRI=DUCTILE)
DMGINI | DMGINIID | CRI | FLAT | LODE | |||||
Y1 | X1_1 | X1_2 | X1_3 | ||||||
Y2 | X2_1 | X2_2 | X3_3 | ||||||
Y3 | X3_1 | X3_2 | X3_3 | ||||||
Example 1 (Format I)
DMGINI | 20 | MAXS | |||||||
20.0 | 50.0 | 50.0 |
Example 2 (Format I)
DMGINI | 22 | QUADE | |||||||
2.0E-3 | 2.4E-3 | 2.4E-3 |
Example 3 (Format I, with temperature dependency)
DMGINI | 22 | QUADE | FLAT | ||||||
2.0E-3 | 2.4E-3 | 2.4E-3 | 20.0 | ||||||
2.5E-3 | 3.0E-3 | 3.0E-3 | 100.0 |
Example 4 (Format II)
DMGINI | 22 | DUCTILE | |||||||
0.03 |
Example 5 (Format II)
DMGINI | 22 | DUCTILE | FLAT | ||||||
1.5 | -0.33 | 0.0 | |||||||
0.25 | 0.0 | 0.0 | |||||||
0.12 | 0.667 | 0.0 | |||||||
0.75 | -0.33 | 1000.0 | |||||||
0.125 | 0.0 | 1000.0 | |||||||
0.06 | 0.667 | 1000.0 |
Example 6 (Format II, Ductile damage initiation with LODE)
DMGINI | 22 | DUCTILE | FLAT | LODE | |||||
1.5 | -0.33 | -1.0 | 0.0 | ||||||
0.25 | 0.0 | -1.0 | 0.0 | ||||||
0.12 | 0.667 | -1.0 | 0.0 | ||||||
0.75 | -0.33 | 1.0 | 0.0 | ||||||
0.125 | 0.0 | 1.0 | 0.0 | ||||||
0.06 | 0.667 | 1.0 | 0.0 | ||||||
1.5 | -0.33 | -1.0 | 1000.0 | ||||||
0.25 | 0.0 | -1.0 | 1000.0 | ||||||
0.12 | 0.667 | -1.0 | 1000.0 | ||||||
0.75 | -0.33 | 1.0 | 1000.0 | ||||||
0.125 | 0.0 | 1.0 | 1000.0 | ||||||
0.06 | 0.667 | 1.0 | 1000.0 |
DMGINIID | Damage initiation
CRI | Damage initiation criteria.
No default (Real) |
LODE | Valid only for
CRI=DUCTILE. Valid for
Format II only. Flag to activate load parameter dependence for ductile damage initiation. Default = blank |
FLAT |
Specifies the handling method for y-values outside the specified range of x-values.
V1, V2, V3 |
The maximum value of strain or traction depending on cohesive damage initiation type corresponding to Mode I, II and III. If V3 is blank, V3 = V2. No default (Real > 0) |
[abs] for ‘MAXE’/’QUADE’ criteria in cohesive elements Unit of Length for ‘MAXE’/’QUADE’ criteria in cohesive contacts Force/Length2 for ‘MAXS’/’QUADS’ criteria in cohesive elements Force/Length3 for ‘MAXS’/’QUADS’ criteria in cohesive contacts |
V1_i, V2_i, V3_i |
The maximum values of strain or traction depending on cohesive damage initiation type corresponding to temperature Xi. Format I only. V3_i cannot be blank, even if it is equal to V2_i. No default (Real > 0) |
Xi |
Temperature values to define temperature dependency. Format I only X1 can be blank, if damage initiation constants are temperature independent. No default (Real) |
Y_#, X#_i, X#_j, X#_k | The maximum value of
strain or stress/traction depending on damage initiation type.
For Format I only. No default (Real > 0.0) |
[abs]
for DUCTILE criteria Nm2 for DUCTILE criteria |
- The material identification number should be unique for all MAT1, MAT2, MAT3, MAT8, MAT9, MGASK, MCOHE, MCOHED, DMGINI, and DMGEVO entries.
- Support information for the damage
initiation criteria are:
Analysis Types Criterion Nonlinear Static Analysis, Nonlinear Transient Analysis MAXE, MAXS, QUADE, QUADS, DUCTILE Explicit Dynamic Analysis DUCTILE Element Types Criterion Regular Shell and Solid Elements DUCTILE Cohesive Elements/Contacts MAXE, MAXS, QUADE, QUADS - When the DUCTILE
damage initiation criterion is used, the parameters are used:
LODE flag Y_# X#_i X#_j X#_k Specified Plastic Strain at failure Stress triaxiality Lode parameter Strain rate Blank Plastic Strain at failure Stress triaxiality Strain rate - For additional information about cohesive elements, refer to Cohesive Zone Modeling in the User Guide.
