User-Defined Thermal Material
The MATUSHT Bulk Data Entry, in combination with the LOADLIB I/O Option Entry, allows for the definition of thermal material through user-defined external functions.
The external functions may be written in Fortran, C or C++. The resulting libraries and files should be accessible by OptiStruct regardless of the coding language, provided that consistent function prototyping is respected, and adequate compiling and linking options are used.
Note: User-defined Thermal Material Heat Transfer is currently only supported for Nonlinear Transient Heat Transfer Analysis.
Write External Functions
Subroutine:
subroutine usrmatht(idu, matID, ieuid,
				Integration_Point, Layer, Simpson_Point,
Stater, State,
 nState, drot, props, nprops, temp,
 dtemp, kinc, dt, t_step, t_total, hgen, smat
 userdata, ierr)
      character*32000 userdata
integer*8 i, idu, matID, ieuid, nState, nprops, kinc, ierr
integer Integration_Point, Layer, Simpson_Point
      double precision Stater(nState), State(nState)
      double precision drot(3,3), rmat(nprops)
      double precision etempmat, dtemp, dt, t_step, t_total
      double precision hgen, smat(9)
initusr subroutine:
subroutine initusr(idu,nstate,cstate)
      implicit none
      integer idu,nstate
      character*64 cstate(nstate)
The strings in the initusr subroutine should always be declared as follows:
The declaration should always use 64-character size.
After declaration, the cstate variable can be assigned the label to print in the user-defined results with 1 being the index for the first variable in the example below:
	cstate(1) = “Variable Name for State(1)”
Note: Subroutine names should not be changed.
Subroutine Arguments
The following table briefly describes the arguments which are passed among OptiStruct and the external subroutines.
Argument Type Input / Output Description
idu integer Input This is defined via the USUBID parameter on the MATUSHT Bulk Data Entry. This argument can be used to define and choose between different types of materials within the same user subroutine.
optional use
matID Integer Input Material ID.
ieuid integer Input Element ID.
Integration_Point Integer Input Gauss Integration Point.
Layer Integer Input Laminate Layer.
Simpson Point Integer Input Through-thickness Simpson Integration Point.
drot(3,3) Double (table) Input Transformation matrix.
props double (table) Input This table contains all the user-defined thermal material property information from the PROPERTY continuation line of the MATUSHT entry.
nprops Integer Input This is the total number of thermal material properties defined on the PROPERTY continuation line of the MATUSHT entry.
temp double Input This is the temperature at the end of the current increment.
dtemp double Input This is the temperature increment of the current increment.
kinc integer Input Current nonlinear increment.
dt double Input Current time step increment
t_step double Input Current subcase time of the current time step.
t_total double Input Total time (if IC is used). This is effective when the IC case control entry of a nonlinear transient thermal subcase points to a previous nonlinear transient thermal subcase.
Stater double (table) Input Table of State variables at the last converged time-step. They are constant between iterations of the same time step.
State double (table) Input/Output Table of State variables at the current time-step. They are updated and passed between iterations of the same time-step. State variables are variables that can be requested as output in the H3D file. Any variable calculated within the solution process in the subroutine can be output by defining it as a state variable.
nState integer Input Number of State Variables that the user requires in the subroutine. See Stater for more information.
cstate string Output A character-based label from initusr subroutine to OptiStruct. In the usermaterial or smatusr subroutines the state variables can be assigned user-defined labels which can be displayed in the H3D file when imported in HyperView. The cstate variable provides the name for the state variable declared in the subroutines to display in the H3D file.
hgen double (table) Output Generated heat.
smat Double (table) Output Material matrix. These are calculated during the solution and are output to OptiStruct. Format for smat matrix is provided below.
smat(1): KXX Thermal Conductivity
smat(2): KXY Thermal Conductivity
smat(3): KXZ Thermal Conductivity
smat(4): KYY Thermal Conductivity
smat(5): KYZ Thermal Conductivity
smat(6): KZZ Thermal Conductivity
smat(7): CP Heat Capacity per unit mass
smat(8): RHO Density
smat(9): Free Convection Heat Transfer
Coefficient (Unused).
userdata Character Output User-defined message that is output based on the value of ierr argument.
ierr Integer Input/Output Flag that activates/deactivates Output message for an OptiStruct run from the user subroutine.
0 (Default)
No action.
1
The OptiStruct run errors out and an ERROR message is printed based on the message defined in userdata argument.
-1
The information message defined in userdata argument is printed and the OptiStruct run continues.
Output
Regular Built-in OptiStruct output, like Grid Temperatures, Element Fluxes, and so on can be requested for any thermal material user-subroutine based model. Additionally, user-defined output can also be requested via the State(*) variable in the user-subroutine. The number of such State(*) variables should be identified on the NDEPVAR field.
This State variable can be assigned to any output variable that is required to be output from the subroutine, and it can then be visualized in HyperView after loading the H3D file.
Build External Libraries for User-defined Materials
You can build shared libraries on Windows or Linux.
Refer to Build External Libraries for more information.
