Build External Libraries
- External Optimization Responses (DRESP3 Bulk Data
                            Entry)
For responses which are not directly available via DRESP1 or DRESP2 entries, you can create your own responses in Fortran/C and build corresponding shared libraries for OptiStruct to use during the solution. Refer to External Responses for additional information.
 - User-defined Structural Materials (MATUSR Bulk Data
                            Entry)
For materials which are not directly available via MAT# entries, and/or for additional flexibility in the material definition, you can create your own materials using Fortran/C/C++ and build corresponding shared libraries for OptiStruct to use during the solution. Refer to User-Defined Structural Material for additional information.
 - User-defined Thermal Materials (MATUSHT Bulk Data
                            Entry
For thermal materials which are not directly available via MAT# entries, and/or for additional flexibility in the material definition, you can create your own materials using Fortran/C/C++ and build corresponding shared libraries for OptiStruct to use during the solution. Refer to User-Defined Thermal Material for additional information.
 - User-defined Heat Transfer Properties
The QVOL, PCONV, QBDY1, and SPCD entries can be defined with QVOLLIB, PCONVLIB, QBDYLIB, and SPCDLIB to create user-defined heat transfer properties in Fortran/C/C++ and build corresponding shared libraries for OptiStruct to use during the solution. Refer to User-Defined Heat Transfer Properties for additional information.
The following sections illustrate the process of building external libraries using Fortran/C.
Windows Systems with Microsoft Visual Studio
Creating dynamic libraries in Windows with Microsoft Visual Studio can be done as follows. First create a new Project and in the New Project window, choose one of the following paths:
For Libraries built with Intel Visual Fortran compiler:
New Project > Intel Visual Fortran (Template) > Library > Dynamic Link Library
For Libraries built with C compiler:
- For Fortran libraries, you need to change the argument passing conventions in the project settings. Under the Fortran tab, select the category "External Procedures" and then change the "Argument Passing Conventions" to "C, By Reference".
 - On Windows systems,
%PATH%must be set correctly to ensure that the right compiler DLLs are picked up at runtime.
Linux Systems
- Create object files using either Fortran or C,
                            as:
For Fortran:
FC [options] -c myfile.F -o myfile.oFor C:
CC [options] -c myfile.c -o myfile.o - Create Shared Libraries, as:
LD -shared [options] myfile.o -o mylib.soWhere,FC- The Fortran compiler (for
                                        instance
ifc) CC- The C compiler (for instance
ccorgcc) LD- The linker (for instance
ld) installed on your computer
Refer to your system's manuals for more information.
The compiler and linker options provide information about the platform you are
                building the library for. OptiStruct is a 64-bit
                application and therefore, only works with 64-bit shared libraries or DLLs (the
                corresponding options to build 64-bit shared libraries should be used). The linker
                option “-shared” specifies that you are building a shared library
                (when using either Intel or GNU compilers). Other options, such as code optimization
                parameters, are left to your discretion and should not usually affect the
                compatibility with OptiStruct.
The following table defines options for each of OptiStruct's release platforms, which have been verified to work correctly on various systems. Keep in mind that these options might change depending on the compilers and linker installed on your computer. Refer to your operating system manual for further information. In most cases, GNU compilers can be used in place of Intel compilers. Use the appropriate compiler and linker options to create a shared library with the compiler of your choice.
Export Subroutines/Functions to Shared Libraries
- Export from Fortran:
!DEC$ ATTRIBUTES DLLEXPORT :: <subroutine name>The
!DEC$ ATTRIBUTES DLLEXPORTcommand should be used to export the subroutine to the shared library. - Export from C:
__declspec(dllexport) int <subroutine name> (<arguments>)The
__declspec(dllexport)command should be used to export the function to the shared library.
You can generally use Native C compilers on both Linux (gcc) and Windows (cl.exe), or Intel C compilers (icc) can be used to create shared libraries in C. If using Fortran, then Intel Fortran Compilers can be used to create shared libraries in Fortran. The Compiler version numbers should typically be chosen within the minor releases of the corresponding compiler versions used to build OptiStruct.
To
                    determine this, you can run the OptiStruct script or
                    Compute Console (ACC) GUI with the -buildinfo run option (the
                        Use Solver Control check box should be unchecked on
                    the GUI) to obtain information about the compilers used to build OptiStruct executables and use similar compiler versions
                    to build the shared libraries. This information is under the header “Build
                    Information” in the screen output after the -buildinfo run
                    option is used.
| Platform | Fortran Compiler Options | C Compiler Options | Linker Options |
| Win64 | /iface:default
                                        /libs:dll /threads |
                                    /MT |
                                    /LD |
| Linux64 | -fPIC |
                                    -fPIC |
                                    -shared |
nm mylib.so on Linux systems and dumpbin/exports
                        mylib.dll on Windows systems with Microsoft Visual Studio. This
                    command will display the list of symbols found in the library, among which you
                    should recognize the function(s) which you have written.
