CSEC6
Bulk Data Entry Defines a planar, 2nd order, six-noded element used in the definition of arbitrary beam cross-sections.
CSEC6 | EID | PID | G1 | G2 | G3 | G4 | G5 | G6 |
CSEC6 | 10 | 100 | 3 | 4 | 5 | 6 | 7 | 8 |
- Element identification numbers within a section definition must be unique with respect to all other element identification numbers within the same section definition.
- Grid points G1 through
G6 must be numbered as shown here:
Figure 1. - This entry is only valid when it appears between the BEGIN and END statements.
