GRIDS
Bulk Data Entry Defines a grid point on the y-z plane, using cartesian coordinates, for use in the definition of arbitrary beam cross-sections.
| GRIDS | ID | Y | Z |
| GRIDS | 101 | 1.1 | 2.1 |
| ID | Identification
                                    number. No default (Integer > 0) | |
| Y | Y
                                location of the grid point. No default (Real) | |
| Z | Z
