CSEC4
Bulk Data Entry Defines a 1st order, four-noded element used in the definition of arbitrary beam cross-sections.
CSEC4 | EID | PID | G1 | G2 | G3 | G4 |
CSEC4 | 10 | 100 | 3 | 4 | 5 | 6 |
- Element identification numbers within a section definition must be unique with respect to all other element identification numbers within the same section definition.
- This entry is only valid when it appears between the BEGIN and END statements.
