Bulk Data Entry Defines a two-noded element used in the definition of
        arbitrary beam cross-sections.
        | (1) |
        (2) |
        (3) |
        (4) |
        (5) |
        (6) |
        (7) |
        (8) |
        (9) |
        (10) |
| CSEC2 |
EID |
PID |
G1 |
G2 |
                            | (1) |
                            (2) |
                            (3) |
                            (4) |
                            (5) |
                            (6) |
                            (7) |
                            (8) |
                            (9) |
                            (10) |
                            | CSEC2 |
                            71 |
                            4 |
                            3 |
                            4 |
                            | Field |
                            Contents |
                            SI Unit Example |
                            | EID |
                            Element identification
                                    number. No default (Integer > 0)  |
                            | PID |
                            A PSEC section property entry identification
                                    number. Default = EID (Integer >
                                0)  |
                            | G# |
                            GRIDS section grid points identification
            - Element identification numbers within a
                    section definition must be unique with respect to all other element
                    identification numbers within the same section definition.
            - This entry is only valid when it appears
                    between the BEGIN and END
                statements.
