MKAERO1
Bulk Data Entry To input a table of Mach numbers (M) and reduced frequencies (K) for aerodynamic matrix calculation, in unsteady aerodynamic analysis.
MKAERO1 M1 M2 M3 M4 M5 M6 M7 M8
K K K K K K K7 K8
In this example, there are 2 Mi values and 8 Kj values. All combinations of (Mi, Kj) pairs will be generated for calculation of the aerodynamic matrix, resulting is 18 (Mi, Kj) pairs.
MKAERO1 0.3 0.69
0.010 0.033 0.067 0.201 0.335 0.470 0.604 0.671
Definition
Mi Value of Mach number.
No default (Real ≥ 0.0)
Kj Value of reduced frequency.
No default (Real > 0.0)
  1. Aerodynamic matrices will be computed using all combinations of Mach number and reduced frequency pairs (Mi, Kj) from the table. This is different from MKAERO2, where aerodynamic matrices will be computed only using the defined set of pairs (Mi, Kj).
  2. In case of MKAERO1, the continuation line (Kj) is required. This is different from MKAERO2 where the continuation line is not allowed.
  3. Multiple MKAERO1 entries are allowed.
  4. To obtain accurate results in Doublet-Lattice Method (DLM), it is recommended to ensure that Kj values satisfy the following relationship.
    max . ( K j ) < ( C ¯ 4 Δ x ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaciyBaiaacg gacaGG4bGaaiOlaiaacIcacaWGlbGaamOAaiaacMcacqGH8aapdaqa daqaamaalaaabaGabm4qayaaraaabaGaaGinaiabgs5aejaadIhaaa aacaGLOaGaayzkaaaaaa@4333@
    Where,
    C ¯ MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGabm4qayaara aaaa@36D6@
    Reference chord length (REFC field in AEROS entry).
    Δ x MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeyiLdqKaam iEaaaa@385A@
    Representative box chord length in the panel mesh.
  5. This entry is supported only with Flutter Analysis.
