MBMNTE
Bulk Data Entry Defines an expression moment at a grid point by specifying a vector.
| MBMNTE | SID | G1 | CID | EID | G3/N | N | N | G2 |
| MBMNT | 3 | 345 | 4 | 0.0 | 1.0 | 0.0 |
| SID | Load set identification
                                    number. No default (Integer > 0)  |
| G1 | Grid point identification
                                number where the action force is applied. No default (Integer > 0)  |
| CID | Coordinate system
                                identification number. Blank or 0 infer the basic coordinate
                                    system. Default = 0 (Integer ≥ 0, or blank)  |
| EID | Expression identification
                                number of the MBVAR entry
                                that gives the load measured in the coordinate system defined by
                                    CID. No default (Integer > 0)  |
| G3 | Grid point identification
                                number to optionally supply N1,
                                    N2, N3 in conjunction with
                                    G1. (Integer > 0)  |
| N, N, N | Defines the direction of
                                the force vector. At least one of the vector components must be
                                    non-zero. Default = 0.0 (Real)  |
| G2 | Grid point identification
                                number where the reaction force is applied. If blank or zero, the
                                force is an action-only force. Default = 0 (Integer ≥ 0)  |
